Been looking in to how i can configure my MK802IIIS to use an external WIFI adapter.... as the title may have suggested, haha! Looks as though some USB adapters just work whereas some need to either have the kernel recompiled or have a module loaded.
I just bought a cheap adapter with the MediaTek/Ralink RT5372 Chipset, as it did say it was compatible with Android, But when connected it doesn't appear to work.
While i have dabbled in compiling linux, mainly firmware for my routers, and the process looks much the same, the micro USB port on my unit has snapped off so i couldn't flash a new kernel if i made one.
My only hope is that its possible to add a module of some sort and edit some config files.
I'm running on Neomode's CR2.0 for the 802IIIS and i found the linux drivers on the Mediatek website but i'm not sure how to proceed.
Any advice would be greatly appreciated.
Many thanks
