Can not boot in recovery via toothpick or any other way from android.
    I have M8 Square amlogic. I have bought 20 of this and nearly 50% of the boxes can not boot into recovery. Following i have tried:
    - Toothpick methode (Will boot straight to android)
    - Tried flashing from Flashify App - (App crashes when i try to select recovery image)
    - Tried from adb(wifi) Shell (gets error saying recovery partition not found)
    I have a compatible recovery.img with me.
    Please advise how can i create recovery partition. I am trying to avoid opening box. My ultimate objective is to install Openelec
    Do a search on forums get amtools bootcardmaker extract the files use bootcardmaker to format a sd card and insert u-boot.bin file in zip. Then give it's a try with toothpick method with sd card.in amd see if it boots to recovery
    Sent from my D6603 using Tapatalk
      just to be clear.
      1. format sdcard with bootcardmaker
      2. zip theu-boot.bin
      3. try with toothpick method
      Correct?
      Thanks mate, i will try that tonight.
        usb burning tool
          Originally posted by sunnythakkar_2005 View Post
          just flash it via android ui Backup / Update
          Bugs are Sons of Glitches!
          JustMe
