Give your opinion on different chipset s for TV Boxs in current market, I have mine
Minix tend to use Intel more, a famous one , which can work with different file formats. and Tronfy MX2 which use H3, which has a better decoding capacity, and the its new released MX4 use Amlogic S812, which makes tv box works more smoothly. and tronsmart uses RK more, which i know little. I am not a highly professional tech guy, anything wrong?Tags: None
I don't get the question
But if you seek to make a review.. buy them all...
Rk3288=horsepower
H3 = cheap mediaplayer
H8=another octa-core..where no benchmark can make it use all cores
A80=overpriced in everyway
S805=cheap mediaplayer
S802=middle range
S812=high price
S90*=not enough info
Rk3388=64bit (with only 1/2GB ram? What's the point) abit less horsepower
Intel=small form PC.. with no HW upgrades possible
--the all suffer from overheating, the are all clocked lower then specs/resellers report
Allwinner=has raw sound passthtough (DTS/Dolby) / vivid colors (no support/development)
Amlogic=good support / smooth Vids
Rockchip=plays everything
Think its a GHM - Ford - Chrysler type of question....well that's how I see it. could be wrong
There all just as good and bad as each other all have Pro's and Con's and most are selling the same stuff in a different Box
I guess its what works best for you.
Some say you pay for what you get but even then that can fail.
In most it's just what works.
Cheers
Rk3288=horsepower
S802=middle range
S812=high price
If you want to buy a project for $100 and try to make it work, you are signing up for dealing with disconnecting everything, reflashing with fingers crossed, then reconnecting. If it boots, then reinstalling apps...I've done that most recently with RK3288 - great performance potential - crap firmware / support. I had to add mod my box for a cooling solution to try gaming... it wasn't nearly as quiet as I'd hoped. It was frustrating.
Two months ago I ponied up for NVidia Shield TV. I will never look back. It continues to amaze me with performance and features. Awesome gaming, its absolutely silent without overheating. ITS FAST. Every game available through the play stores has been tested to work with it. No more downloading 2GB and find out its incompatible with a controller/mouse setup. I connect my 10 year old USB steering wheel & pedals and they work with 80% functionality (not all on-board buttons supported with all apps). I love the streaming games from Shield Hub... It's a winner.
(I'd recommend 500GB model for gaming without worrying about space usage but the 16GB model is probably fine for most.)
Originally posted by eebrains View PostIf you want to buy a project for $100 and try to make it work, you are signing up for dealing with disconnecting everything, reflashing with fingers crossed, then reconnecting. If it boots, then reinstalling apps...I've done that most recently with RK3288 - great performance potential - crap firmware / support. I had to add mod my box for a cooling solution to try gaming... it wasn't nearly as quiet as I'd hoped. It was frustrating.
There are currently 2243 users online. 2 members and 2241 guests.
