Windows 10 upgrade for Bay Trail devices?
    Hi guys just wanted to know if there's any problems I need to be worried about before upgrading bay trail devices to Windows 10? Are drivers etc fine? Wanted to make sure before potentially ruining my device thanks.
    if you do upgrade you will be fine..if you do a fresh install you will need drivers
      If you do a fresh install you will have license key problems, but I didn't notice any drivers problem with it.
      To avoid the license key problem you need to upgrade before the clean installation.
      My devices:
      Gearbest.com)
        I make the upgrade recived for my Ainol mini pc .All is ok perfect functionality.No problem at all the version is W10 Home full activated.It take aprox 45 minutes to make the upgrade process!
