Audio in / MIC support on T428
    I am using the T428 with the finless rom that was posted.
    I am having an issue that the MIC/Audio input does not work.
    I am using the T428 with the KP-810 http://www.geekbuying.com/item/KP-81...ne-314722.html.
    It has Audio input/MIC but the T428 says there are no audio input devices.
    Any help would be appreciated.
    Yep, I can confirm. I plugged in my cheap 2.1 sound adapter by Saberent and it is not seen.
    So it appears 4.2.2 is missing many audio device drivers unlike 3066 sticks.
    I will see what I can do about that.
      Thanks Bob
      Thanks for looking into this Bob - even the latest 4.2.2. rom from tronsmart doesn't address the audio input problem. There seems to be no way to get a mic input into this device. I've tried a webcam with mic, a cheap usb audio stick, and a Bluetooth headset. Geekbuying told me that their usb audio stick would work but it does not.
        Also transfer the problem to tronsmart, and see when they can fix that.
        Looking for developers
