i never get my mk808b original rk903 to work. Got the 2a power.
got an rca rled2845a hd ready tv.
Spec:
led panel
16:9
1366x768
480i,480p,720p,1080i,1080p (auto-detect scan not manually configurable)
supported hdmi port resolution:
resolution - horiz scann freq - vertical scan freq - format
720x480 - 31.47 - 59.94 - 480i
720x480 - 15.734 - 59.94 - 480p
1280x720 - 37.5 - 50 - 720p
1280x720 - 45 - 60 - 720p
1920x1080 - 31.25 - 50 - 1080i
1920x1080 - 33.75 - 60 - 1080i
1920x1080 - 27 - 24 - 1080p
1920x1080 - 56.25 - 50 - 1080p
1920x1080 - 67.50 - 60 - 1080p
i try every roms (720p and 1080p) finless (thx finless great devel),lewi (thx lewi great devel), hybrid, geekbuying, stock with no luck, i also see that the first time i flash in rktool i've got a pink square. No way to get the "Found RKAndroid Mass Storage USB" now to flash the only way is the paperclip option that give me a green one. "Found RKAndroid Loader Rock USB" of course i use the finlesstool too, both flash mk808b without errors. In device manager i see 'class for rockusb device/RK30 Device'. I try the nice nand unbrick tip from finlessbob to put in the MASK ROM mode to fix a possibly nand error, but nand is ok. I try to 'adb shell' as for my rooted smartphone with no luck, no mk808b adb device driver in device manager anyway.... i buy a 28$ 5v powered pal/ntsc switchable hdmi to av(rca) for nothing too...
There's a thing i miss ? I read and read all over different forum like a noob, some say: cheap hdmi cable,insufisent power,bad nand...the only thing i havn't read is someone that buy a tv directly from the chinese rk manufacture
Omagamoon (thx omegamoon great devel) seem to give a clue for the 'no signal/black screen ' issue but seem to be for mk808 only due to kernel. If i take the omegamoon mk808 kernel i'll loose BT for sure but wifi too ? And how to get back my mk808b to have a pink square in rktool (i cannot do the 'switch' )? And in finlesstool 'reboot to flash mode' give me a ' Device can not do flash mode, because it is not msc device'.
Any sugestion from the guru before i put it to garbage ?
Regards
sorry my bad english, i don't speak english everyday.
if only i bought a mk808 instead and if my lg-c800g 1ghz could only have a video output.... hé hé
