HELP with MKV809IV - GXT_D16_LP_V1.8 150310
    The only working rom for this device that i have found is here: https://drive.google.com/file/d/0B_w...ZEOXJNaDg/view (4.4 kitkat original rom from manufacture)
    problems:
    1. the device is extremely slow working (kitkat 4.4)
    2. it has a stutter problems when running HD (720p or 1080p) video's. frames keep skipping.
    3. wifi reception very poor.
    help needed:
    1.for the first problem as far as i can tell it needs to be downgraded to kitkat 4.2 but NONE of the ROMS i have found here on the forum seams to work on the stick. (wont boot)
    so any suggestions on how to create one that will work would be appreciated. this is what i get:
    2.I understand the the video problem is caused by VSYNC problem and that i need to run a modified perl script on my kernel but i was unable to do it. i have WIN7 comp. and
    none of the astiveperl i installed would run the script, this is what i got:
    i would appriciate if anyone could run he script on my kernel and upload it for me.
    the link to my kernel file: https://www.dropbox.com/s/byjaxsoceq...ernel.img?dl=0
    3. i found a solution of sorts for this problem by moving the device away from my tv as possible and changing my house wifi to "N" ONLY. that got me up to 30mbps.
    I have the same device , and I can not find a room to function properly
    I also need help
      anyone?
      i have tried to date every consivable rom posted here.. no joy!
      plz, if any of you know how to crack a kernel my problem is strictly with mine and there are no replacments available...
