808b, here the new 4.2.2 firmware with kernel 16 april (cwm backup)
    hi if this can useful for someone:
    a cwm backup of stock firmware android 4.2.2 with kernel date 16 april
    though I do not see changes
    808b_cwm_backup_4.2.2._16april.rar (201.3 MB)
    MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
    i use this cwm:
    MK808B_CWM.zip (6.3 MB)
    you can flASH IT by stoch recovery
    for go in the recovery mode you must out a needle in a little hole near blue led and put power ( no use otg)
    Re: 808b, here the new 4.2.2 firmware with kernel 16 april (cwm backup)
    i use this cwm:
    Thanks for share it, did you see any improvements compared to first 4.2.2 released by geekbuying?
    How are your fellings with this version?
    I will test it soon.
    My devices:
    Gearbest.com)
      MK808B New FW 4.2.2 from Factory direct
      I got some issue with this software. After applied, I got wireless connection can’t start. I contacted reseller and he routed me to China factory. After sopken to factory, they gave a firmware which they said final version to reload to MK808B. By using this I can recovered back wireless LAN and now seems to be stable. I am sharing for anyone who needs it…Here is a link to download…
      4shared is a perfect place to store your pictures, documents, videos and files, so you can share them with friends, family, and the world. Claim your free 15GB now!
        sorry but i don't have the "old" firmware.... so i cannot know changes....
        i tried old firmware only for unbriking....no test
          I will try both.
          My devices:
          Gearbest.com)
            tomorrow i will try the firmware post by tuntun
            leo
            see in its update.img i see the system in more 600mb.... so you cannot use parameter file of Bob ( in here system has only 512mb) for this reason i could not make restore of system in cwm :-P
            i thinks that it is same 16 april ....
            for my backup cwm i have deleted useless app and game....
              I can make a new parameters file if you want, we must take a look too about kernel size, in the 4.2.2 that geekbuying give to us the kernel had more than 8Mb so it didnt fit too in the standard parameter file that Bob give to us. Tomorrow I will try, and if it is more "well finished" than the prevoius one, and like Bob is working in the quad cores I will try to tweak a little bit this rom. Tomorrow I will give you more news.
              My devices:
              Gearbest.com)
                ok, both roms are the same one, thanks to you for sharing it, it feels better than the previuos rom, i have it rooted (very easy cause it comes prerooted) and I will make some test on it before pass it to the kitchen. My general feelings is that this rom is a bit slower than 4.1.1, but a lot of more good finished than the stock 4.2.2 beta rom that Erik from geekbuying kindly give us before.
                More news come soon, stay tunned. And It comes with a 1080p kernel by default.
                My devices:
                Gearbest.com)
                  good!
                  i make a new parameter file with 4gb of apps, 1gb for system and near 2gb for data :-)
                  and with it seem that i no have problems with wii-fii and inserted sd
                  parameter4gbmod (603 B)
                  thanks a lot :-)
                  now i want try to mount systen.img in linux for delete all chinese game and useless apps...
                    But the stock user app size is 2gb, like standatd Bob roms, looks good for me, not enought size for you?
                    Different users in this Rom is bugged too how enter in the other user account once it is created? We need a funtional screenlock to made that, not way to select usb connection to pc in gui.
                    About bloatware, yes it has a lot by default, you can delete that apps with a root explorer from android.
                    I have the Rom divided in the standard img files.
                    My devices:
                    Gearbest.com)
                      ok... i have mounted system.img in linux....
                      i have deleted useless apps...
                      i put superuser and busybox
                      i have unmounted system.img
                      but the file is alwasy more of 600mb... but now with used space of 400mb and free space 200mb,,,,
                      how i can resize the system.img under 512mb?
                      can I do it?
                      sorry if the question is stupid :-)
                        Can someone give me a better link to download this?
                        4shared wont work for me.
                        Thanks,
                          Thanks,
                          Uploading it to my dropbox I will give you the link in PM. Are you planing to make your magic with this rom?
                          Angelobiz: to change system.img size you need to make a new empty file.img with dd and then with mkfs.ext4 format it in a ext4 filesystem, after you need mount both img files and copy your old filesystem to the new one.
                          My devices:
                          Gearbest.com)
                            Netflix
                            Hi, have you tried to run Netflix, in my device the video runs with errors.
                              There are a lot of threads informing that Netflix dont work in any 4.2
                              My devices:
                              Gearbest.com)
