T428 Wifi problems kind'a resolved. Great device when it works.
This is weird but the t428 won't connect to wifi routers that are set to AUTO channel. You have to actually set your router's channel to a number. I know a lot of people are complaining about this device but once I was able to connect to my 5ghz wifi I was able to perfectly stream 15gb Blu-ray rips via MX Player. This device is fricking awesome I hope someone takes the time and creates a really good Rom that supports Netflix, Hulu, XBMC. Even the Tronsmart rom is junk. The 4.2 finless rom is the only one that seems like it works pretty well however it was rushed out a little fast. It's to bad the manufacturer can't take some time and release a good rom before shipping out their product. I don't think they should have shipped out this device without a fully working 4.1 and 4.2 rom with @ least Netflix, Hulu plus and XBMC working. So don't give up on this device it's really awesome when it's working.Tags: None
Originally posted by darklotuz View PostThis is weird but the t428 won't connect to wifi routers that are set to AUTO channel. You have to actually set your router's channel to a number. I know a lot of people are complaining about this device but once I was able to connect to my 5ghz wifi I was able to perfectly stream 15gb Blu-ray rips via MX Player. This device is fricking awesome I hope someone takes the time and creates a really good Rom that supports Netflix, Hulu, XBMC. Even the Tronsmart rom is junk. The 4.2 finless rom is the only one that seems like it works pretty well however it was rushed out a little fast. It's to bad the manufacturer can't take some time and release a good rom before shipping out their product. I don't think they should have shipped out this device without a fully working 4.1 and 4.2 rom with @ least Netflix, Hulu plus and XBMC working. So don't give up on this device it's really awesome when it's working.
There are currently 1962 users online. 1 members and 1961 guests.
