I have connected the UART and I was able to get to the boot loader, but I can't seem to be able to access anything else.
anyone have more experience with any of these devices?
If I can at least install another launcher it would be amazing!
The device says "Coship N9085i" but I can't find any info other that a few photos.
I also email Coship support to ask for a generic firmware, and they said "No"
The boot-loader help shows this
mt8658_base # help ? - alias for 'help' base - print or set address offset bdinfo - print Board Info structure bootm - boot application image from memory bootm_zImg- bootm_zImg - boot with zImage in memory bootp - boot image via network using BOOTP/TFTP protocol chpart - change active partition cmp - memory compare cp - memory copy crc32 - checksum calculation dis_log - log_enable ext2load- load binary file from a Ext2 filesystem ext2ls - list files in a directory (default /) ext4load- load binary file from a Ext2 filesystem ext4ls - list files in a directory (default /) fatinfo - print information about filesystem fatload - load binary file from a dos filesystem fatloadex- load binary file from a dos filesystem fatls - list files in a directory (default /) go - start application at address 'addr' help - print online help loop - infinite loop on address range matchfile- match a file in a directory md - memory display mm - memory modify (auto-incrementing address) mmc - MMC sub system mmcinfo - mmcinfo <dev num>-- display MMC info msdc - msdc -msdc performance testing mt85xx_boot- mt85xx_boot - boot command for mt85xx platform mtdparts- define flash/nand partitions mtest - simple RAM read/write test mw - memory write (fill) nm - memory modify (constant address) ota - Reboot and enter recovery mode ping - send ICMP ECHO_REQUEST to network host printenv- print environment variables rarpboot- boot image via network using RARP/TFTP protocol reset - Perform RESET of the CPU setenv - set environment variables tftpboot- boot image via network using TFTP protocol ubi - ubi commands ubifsload- load file from an UBIFS filesystem ubifsls - list files in a directory ubifsmount- mount UBIFS volume upg - upg - Upgrade image sub-system usb - usb - BDP USB sub-system usbboot - usbboot - boot from USB device version - print monitor version
