HI
i have Q7 tv box xt-q7-v10
I buy from http://www.geekbuying.com/item/Q7-TV...ck-324259.html
with stock frimware 4.2.2
i find 4.4.2 frimware for droidstick 15-3 2015 and install
this frimware work very goot but i has problem spdfi out not work passthrough
and i go back in 4.2.2
i flashed 4.2.2 with RKBatchTool 1.7 and have the messege IDB fail
arter that i can't flash any frimware
i try to Erase the IDB using RKAndroid Tool 1.37 the process Finished successfully
but when try to flash frimware with RKBatchTool 1.7 i has the same message IDB fail
I tried to shorting pins 8 9 or 6 7 but not Found the message "MaskRom Rock Usb"
Any help would be valuable
some photos
