RK3288+ picture in picture +recording
    If you want to know more about this product, pls refer the video
    If you have intresting in this product, pls feel free to contact with us :
    [email protected]
    Looks nice. These are exciting times. Release date?
      It's already selling on their Aliexpress page.
        Thanks. Am I right to assume that is the 2GB/16GB version?
          Yes
          But I guess they might also have 4GB/32GB models or can manufacture if demand is high.
          You can also combine it with different remotes and people can message them for what they want.
          Next week I'll hopefully test their RK3368.
            Currently, its 2G/16G+ ap6335(802ac)+ RK3288+ Toshiba hdmi in chip. if you have any intresting , pls take a review here
            Best regards
              I'll be looking forward to your impressions on both of these new boxes.
                Please try testing the new ROM with passthrough fixes.
                It should work on HPH NT-V6 & HPH NT-V6 with HDMI Recording boxes.
                https://drive.google.com/file/d/0B2J...ew?usp=sharing
                If there are still passthrough issues, I'll try something different.
                If it works I'll make a custom ROM later.
                  New features with HDMI-IN Box
                  Operation tips:
                  1.Click on the HDMI in app
                  you will see the picture of your HDMI out device, this is pass through function
                  short press menu button of remote controller,you will see the recording function:
                  Long press menu button, the PIP function is called out:
                  while you will see the background video stop playing.
                  If you keep Long press the menu button, you will call out the operation menu of PIP:
                  There are four selections, move, scale, audio and exict.
                  If you want to exit the PIP function, you have to chose exit by the right top operation menu.(only way to exit):
                  If you want to exit the HDMI in function, just click back button of remote.
                  2.Not in HDMI in app page.
                  this one is you can call out the PIP directly in main page, like below shows, just need to long press menu button:
                  while if you want to operate the PIP , just long press the menu button again to call out the operation page:
                  For window operation: you need to chose it (you can see a Green BORDER in the window), cancle chose: just click the Back button of remote.
                  More: if you connect the mouse to operate, then you can't use the remote contreller to operate, because it just can identify one operation.
                    Video of HDMI-IN Box Possibilities
