I've downloaded the recent Kodi from kodi.tv for my Android S812 . Both devices purchased from Acemax . one is M8S and another is S806 (yes: by CNX).
The problem is that Kodi menus are well positioned but once getting into movie full screen , it will show the top left corner of the movie (subtitles and other overlay menus are still good).
One solution I found is to edit the xml discriptors and switch to another Android player : but then I loose the subtitles menus and such.
Kodi forum suggests disabling amlogic codec but this will stop the player from showing movies.
I must say this never happens on my OpenElec .
Android MBoxSetting HDMI is set to auto (or manual): 720p@60Hz but Kodi-->System-> SystemInfo --> says 1920x1080 .
As if Kodi doesn't read the Android screen size correctly.
opening the movie file in the build in Android movie player works just OK.so its something with Kodi source.
Any other solution ?
