I have been interested in buying a cheap box that comes with gigabit LAN and without heat issues.
Been looking around but I am still to find such a box , do you guys have any suggestions about available or soon to come boxes for me?
EDIT:
Specs that would be ideal for me would be:
> Intel Based CPU
> 64Bit Windows OS
> 4Gb Memory
> USB 3.0
> Gigabit LAN
> Remote control via a RC or Keyb/Mouse
EDIT2: (thanks to trebor)
I have come to the conclusion that I have to go for a NUC for my needs, posting it here if it helps anyone:-
Tronsmart Ara B19 (Weight <400grams, Gigabit LAN, 1x USB3.0 port, 3x USB2.0 ports, Display port + HDMI, CPU QuadCore Intel J1900)
[$115.99] (http://www.aliexpress.com/item/Trons...398227878.html)
4GB DDR3L
[$24.29] (http://www.aliexpress.com/item/DDR3L...398274227.html)
1TB 2.5 HDD (will open up external 2.5 HDD case and put the HDD inside the NUC)
[$58.89] (http://www.****.com/itm/111485362248...%3AMEBIDX%3AIT)
OS
[$~] (any OS of your choosing)
[$199.17] Total cost without OS licensing
