Trouble Flashing!
    Trouble Flashing!
    Hello again friends. I ordered a bunch of boxes from Beelink (the new M-18s) but they put the wrong Logo on the startup. No problem, I'll just reflash them and fix it, right??? NOPE! In fact, when I get into the Recovery Screen, no matter what option I select it just sits there and looks at me.
    I have the new ROM with the correct Logo and Animations, but I can't get the box to do anything past getting to the Recovery screen.
    I tried the USB Burning Tool (Doesn't recognize the Box over the OTG Cable)
    I tried the burnBootcard method and it doesn't recognize any command at all. it just boots to the Recovery menu and sits there. I can scroll through the menu, but selecting any item in the menu does nothing.
    Am I doing something wrong?
    Need your help guys.
    HDChaz
    Do you know how to boot frim efi
    Sent from my SD4930UR using Tapatalk
      There is a veri nice install video tutorial on reflashing by Gadget Friendly.
