Pipo P1 -3G Kernel enabled 3G modem
    hello every one.
    here is a home made kernel for Pipo-p1-3g .
    this kernel is a SElinux Enabled, so it work best with SElinux builds out there .
    link https://www.4shared.com/archive/fPC6...nero-enab.html
    completely newly written 3g driver in kernel .
    test and it is working on the Pipo-p1-3g with Pipo enabled 3G version of P1 LP 5.1.1 ..
    <6>[ 0.871272] [3g_modem]: Enter pipo_p1_3g
    <7>[ 0.871387] of_get_named_gpio_flags exited with status 232
    <6>[ 0.871397] [3g_modem]: modem_platdata_parse_dt: get property: 3G,power_gpio = 232.
    <7>[ 0.871412] of_get_named_gpio_flags exited with status 245
    <6>[ 0.871421] [3g_modem]: modem_platdata_parse_dt: get property: 3G,en_gpio = 245.
    <6>[ 0.871434] [3g_modem]: initing 3g_modem
    <6>[ 0.871454] [3g_modem]: by mussonero
    <7>[ 0.871484] _gpio_request: gpio-0 (3g_modem_power_reset) status -16
    <6>[ 0.871494] [3g_modem]: 3G-Modem device registered.
    <6>[ 3.527566] usb 3-1: New USB device found, idVendor=0e8d, idProduct=00a7
    <6>[ 3.527581] usb 3-1: New USB device strings: Mfr=9, Product=10, SerialNumber=0
    <6>[ 3.527591] usb 3-1: Product: Product
    <6>[ 3.527599] usb 3-1: Manufacturer: MediaTek Inc
    <6>[ 3.528655] cdc_ether 3-1:1.0 usb0: register 'cdc_ether' at usb-ff540000.usb-1, CDC Ethernet Device, 02:00:ff:aa:aa:aa
    <6>[ 3.529022] option 3-1:1.2: GSM modem (1-port) converter detected
    <6>[ 3.529195] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
    <6>[ 3.529485] option 3-1:1.3: GSM modem (1-port) converter detected
    <6>[ 3.529615] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
    <6>[ 3.529897] option 3-1:1.4: GSM modem (1-port) converter detected
    <6>[ 3.530031] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
    <6>[ 3.530318] option 3-1:1.5: GSM modem (1-port) converter detected
    <6>[ 3.530451] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
    Best Regards
    excellent news - welcome
    Donate to Finless
      Just barking a question of... Is there a kernel like this coming for other RK3288 models such as a P4? Good day!
      M8pro
      M9pro (current tab)
        I do not know about P4, if it has the same Tech Specs as P1 or not , but if it dose ,you can try the kernel and use your resource. img
