My Post's not showing up?
Its not just you convict this happens to others too & not just with reviews it happens in all sections, Your post needed to be approved for some reason that's all..It should be visible to all now.
I will move this topic from user reviews now & change the tittle to My post not showing upPlease consider making a Donation to freakTab
I cant see any signs of your missing post bluesmanuk,
If it was something to do with approval I should still be able to see it even when you guys cant But nothing, So im putting your missing post down to the guys doing a vbulletin update as that was going to take place over the weekend.
Has your post shown up now or is it still missing?
Originally posted by blinkone View PostI cant see any signs of your missing post bluesmanuk,
Thanks for the response.
No it hasn't shown up but no biggy if it was likely to co-inciding with a site update.
I can post it again.
Yes Try it once more if you don't mind bluesmanuk but only try it once more though.
Something else strange this guy's avatar (profile photo) is showing your avatar, it has done for the past few hours now, This normally happens when someone is posting a reply
There are currently 1918 users online. 1 members and 1917 guests.
