for some reason i used finless 1.2 and before i do the update i installed the 112k4 stock firmware
after the finless install ended the device reboot and shows the logo for a few seconds and after that a black screen(the blue led is on)
i tried the method that rad described here: http://freaktab.com/forum/tv-player-...=1439927532421
without the part of opening the device and short pins.
before i do that i thought maybe i'm just get panic and my problem is easier to solve
more info that maybe will help to diagnose the problem:
when i connect the vega to my computer it make connecting sound but no success to connect with the usb burning tool
in the device manager it recognize it as mtp usb device
thanks a lot wish you can help me soon
