i68 TV BOX Firmware Update
    1.Netflix——Solved problems of the video can not be played .
    2.Replace the media library "ffmpeg.so" , Optimizing of "4K/ISO/Dolby&Dts" video playback .
    3.Root——Open permissions
    4.Solved the "OTG interface" insert and pull out lead to crash.
    Remark: Not compatible with LAN (1000 MB)
    Chained address:http://pan.baidu.com/s/1eQlkMMe Password:qgvk
    Web: www.azw-online.com
    How to update firmware?
      You can look here http://www.tronsmart.com/?p=3521 Nearly same device. Tronsmart Rom is working on i68. But on Wassers firmware Wlan/Bluetooth isn't working.
      So their must be a small difference.
      For linux you have to use "Linux Upgrade Tool" from rockchip.
        So, if I update with the original tronsmart rom, will everything work?
        I'm thinking about update because I want to have root access, but my i68 works great now, and I'm not sure if I will have a big difference
        Enviado desde mi HM NOTE 1W mediante Tapatalk
          Hy guys,
          Can someone tell me if it's better beelink r89(3288) or beelink i68(3368) ?
          I want to purchase one for an friend.
          Sent from my MX4 using Tapatalk
            Originally posted by Catadarius View Post
            Hy guys,
            If it's mostly for streaming then the RK3368 is more cost effective.
            If it's also for gaming and you want the fastest box then the RK3288 is a better choice as it has a faster CPU & GPU.
              Can you put that firmware somewhere else than Baidu? I can't create an account with them!
              Also, is it possible to have similar fixes and addons as the Wasser firmware?
              Web: http://freaktab.com/forum/tv-player-...-tronsmart-r68
              Thank you!!
                Thank you!!
                Did you find an alternative download link?
                  I will test this one: http://chinagadgetsreviews.blogspot....op-511_84.html
                  UPDATE: It worked! Netflix works.
                    I downloaded the 101L1101 firmware update from that link, and I'd like to install it to fix the Netflix playback issue on my Beelink i68.
                    I assume that I can install it using the Upgrade Tool & instructions found at the page below?
                    http://blog.w2comp.com/2013/08/21/fi...box2-ultimate/
                    Also, does it make any difference whether my i68 supports gigabit ethernet or not? I think it might be one of the early release models that only supports 10/100. I don't want the firmware update to break anything or, heaven forbid, brick the box.
                    Please advise.
                    Thanks!
                      Is everything working with this firmware? is it rooted?
                        Yes, and yes.
                          Please advise.
                          Thanks!
                          I posted this question about 10 days ago, but no replies. I'd really like to make sure I'm using the correct upgrade tool & instructions before attempting the firmare update.
                          Anybody?
                            I'm waiting with firmware install too. I have 100MB ethernet. To check see about device. (version 100L is 100Mbit, 200L is Gigabit)
                              Is the rom from http://chinagadgetsreviews.blogspot.no/ the same rom as in the first post? Is it also rooted? Also... My i68 is RK3368 and this ROM has RK3369 in the filename. Typo? Will it work for sure?
