(I'm writting from México city) so it's clear I don't know enough english to write fluently, but I'll try to make myself clear:
I get a MK809IV, an Android dongle, OR Android TV stick, OR miniPC or whatever the name were.
I bought here:
http://www.****.com/itm/271841070720...%3AMEBIDX%3AIT
Specifications:
Device type: gxt_dongle_3188
Rockchip RK3188 1.6Ghz Quad core + Mali400 GPU Quad Core
Operation System: Google Android 4.4 Kitkat
My interest on that device is turn my "old" LCD television on a SmartTV, use internet (Youtube, Twitter, Netflix), etc. The devise is already install with KODI and other stuff. But is USELESS because I cant connect my WIFI signal.
Summary / Consequences (3 aspects)
ONE (first photo)
Everything looks fine, works ok, BUT when I go to android settings and select WIFI controls, and turn the signal to ON, after a few seconds later wifi is apparently ON, and I can read CONNECTED, but the waves of the wifi logo are just WHITE. Never turn blue or green.
TWO (second photo)
Then, I activate the web navigator APP and try to go google.com, impossible, I only can read:
net:: ERR_NAME_NOT_RESOLVED
THREE (third photo)
When I try to set a google account, the same, impossible to go out to the web. I can only read:
Couldnt sign in. There was a problem blablabla, Try again later.
Maybe its important: I downloaded Moborobo and already rooted the devise.
I am new user on this technology does anyone knows about this problem???
Do you think would be necessary to flash the device and change the ROM?
If someone knows something about this issue, I appreciate and advice.
I noticed a post with a tutorial or something for a similar devise from user neomode
