flash android version on ut3s
    Check out the windowed mode, a.k.a. Light Biz OS. Pretty cool.
      No is not avatr! Is really my dog ​​and called Charly! Since he was young, but he has remained so small and cute!
      Can the Light Biz OS flash as the "normal" 5.1? Where can I download it?
      EDIT
      I have found it, if you mean the version of @ mo123!
        We have a couple of 4-leggers around here too. Dogs are great fun.
        The Light Biz OS features can be turned on in 5.1. See below....Multi Window...
          Yes, dogs are not only fun, they are honest and love you with their whole heart!
          This feature I will try, thank you!
            Yes, I am dog guy through and through. I admire loyalty, few living things are as dedicated as dogs in this way.
            Cheers.
              Hi!
              in Kodi version no PVR client is installed! I have downloaded the pvr_client zip file and installed in Kodi. But I keep getting message: the addon can not be started. How did you solve it?
              EDIT
              Solved! Have the Kodi version deleted and new from Store installed!
                Originally posted by pilik View Post
                Hello there,
                I have solved my problem! Before I tried your suggestion, I connected the box to the computer monitor! And the picture was there immediately. Then I again connected the box to the TV and tried your proposal with the remote control.But it did not work! Then again i connected the box to the computer monitor and the settings I have the resolution changed to automatically!I reconnected to TV and nothing! No picture! Then last attempt; i reconnected the box on the computer monitor and the resolution in the settings to 1920 * 1080p changed. Then when I connected the box to TV the picture was right there !!!
                So it was at the **** resolution of the TV ???
                I got the same problem when flashing Ugoos 3.0.4 firmware on my UT3S, only black screen on my 4K TV when booting after flash.
                So I followed you solution and connected the UT3S to a older TV with only 1080p support and got picture, choosed 1080p 60Hz and turned of the device, connected to my 4K TV and I now got picture :-)
                But from time to time it still mess up and I have to change input port to something else and back :-(
                Did not have this problem with 2.2.0 firmware ..
