Ott 4k m8 reset button
    Am I being totally thick here as I've read its in the av port but there's no click when I insert a tooth pick do all m8 boxes have this or was it left out on some
    its in there just don't be to rough or you will break the switch you may have to align the toothpick as you enter. best way is have the switch pressed in and then plug in power plug and keep holding switch in for 5 to 10sec it should default to recovery screen
    Bugs are Sons of Glitches!
    JustMe
      Thxs for the reply
