Help!!!
Ugoos UT3S WIFI
Originally posted by growgeek View PostWIFI on all ROMS is very poor for my 2 units.... Most Android phones in the same location connect to the router just fine but the ut3s does not.....
Help!!!
The taller flat ones that look like 'ice cream sticks' work very well.
That is what it came with... I also tried an ALFA 9db with limited success....
Is poor WIFI reception a common complaint?
Does your router have 1 or 2 or more antennas?
Are there lots of walls between the device and router?
How far apart are the router and UT3S.
Have you tried setting your router on a different channel?
I get full signal on my HPH RK3288.
There shouldn't be any issues with wifi on the UT3S.
Have you tried a different router?
Originally posted by mitchell4you View PostHmm..
Could also be interference say by using a 2.4 dongle wireless mouse/gamepad close/near the unit (extension cable might help)
Other thing.. check the log of your router (Or look for a OTA upgrade for your router)
Anway..goodluck
There are currently 1831 users online. 1 members and 1830 guests.
