Neomode Custom Build OpenElec 6 -Unofficial- M8 Sqaure and T8
    Hello Guys,
    Here i present you my Custom Build off the OpenElec Media Center in Version 6.0.
    This is an unofficial Build, don´t ask on OpenElec.TV for Support.
    How to install, FAQ, changelog, downloads, source code and previous releases available at:
    Port of the OpenELEC for Amlogic-based TV boxes. Contribute to kszaq/OpenELEC.tv development by creating an account on GitHub.
    Download for M8:
    http://www.freak-tab.de/neomode/open...enElec6_M8.zip
    What Works?
    IR Remonte
    Wifi
    Ethernet
    Streaming
    Download for T8:
    http://www.freak-tab.de/neomode/open...3-g95eb9be.zip
    What Works?
    IR Remonte
    Ethernet
    Streaming
    Wifi is not working right now. Must deeply check why it is not Working.
    This Release is using Kodi Version.
    Regards
    Neomode
    Link to M8 is down.. thanks for your work.
      *FIXED*
      Neomode
        Can u make dual boot openelec and android ?
          This version works great (M8)!!! Thank you
            congrats Neo on your first build on OpenElec rls
            just some feedback its little cpu jumpy & hungry and I'm sure it's a wip thing and people should try this they will be happy:-)
            keep up the good work fellow FreakTab Brother
            Bugs are Sons of Glitches!
            JustMe
              Thanks a lot. I will check on what you say. May it is in Sources I use.
              We will see. I want support more Devices in Future.
              Gesendet von meinem Elephone P7000 mit Tapatalk
                  Is there any way to output audio over the 3.5mm jack on this build?
                    neomode is there any possibility to compile it for MX3 1G ram to
                      Thanks neomode!
                      Hate to be a hater but why ask for this so soon? This is a openelec build.. Not android.
                        No that's OK. @ the Moment i see no Solution on how to make this happened. What may work is to run openelec from SD card.
                        Gesendet von meinem C6603 mit Tapatalk
                          I can't seem to get the official OpenElec repository, nor the unofficial one, open on this build for the M8 for some reason. (But it works for Codesnake's 5.0.3 M8 build), I liked this build better except for that bug, is there a workaround?
                            Hi, Neomode. Could you please provide detailed directions to prepare a bootable SD card (derived from from your OpenElec6_M8.zip) in order to run your build leaving Android unchanged on NAND?
                              Maybe someone have update. tar file for this excellent rom?
