Skin.confluence location
Hi Dan you would get a better response if this was posted in the xbmctalk section for this forum, you maybe able to save bit of time with confluence mods already done by other members
use the super repo and install the skin pack there is virtually 5 confluence skins and another one called convergence which is all customiseable and confluence mod 4 etc.
I'm no expert in this area.Bugs are Sons of Glitches!
JustMe
The skin is part of XBMC/KODI so you won't find it in the MXIII firmware. As Justme said there are some great mods already out there. If you want to edit yourself you'll need to extract the kodi apk and edit the skin files from there or use a file explorer on your box, locate the skin folder and edit that.
As mentioned its hard coded into kodi, although you can download the skin and install it as repo
go to your home.xml file
<include>CommonBackground</include> <control type="image"> <left>0</left> <top>90r</top> <width>1280</width> <height>90</height> <texture>floor.png</texture> <animation effect="fade" time="200" condition="Window.Previous(Home)">WindowOpen</animation> <animation effect="fade" time="200" condition="Window.Next(Home)">WindowClose</animation> </control> <control type="image"> <description>LOGO</description> <left>10</left> <top>5</top> <width>120</width> <height>49</height> <aspectratio aligny="top" align="left">keep</aspectratio> <texture>kodi-logo.png</texture> <include>VisibleFadeEffect</include> <include>Window_OpenClose_Animation</include> <visible>!Skin.HasSetting(homepageWeatherinfo)</visible> </control>
and change the visibile to false you can also remove the logo doing the same. or as mentioned in erlier post you can download confluence skins already modded where all you do is check and uncheck a box to remove the black bar or osd and also the logo etcBugs are Sons of Glitches!
JustMe
There are currently 1201 users online. 2 members and 1199 guests.
