some boxes have the ocmpatiblity problem with some apps, the problem may lie in the fact that this box only work with a certain app version, so you can try some other versions and it may work. My tronfy smart box also give me the same trouble as I can not run my sixaxis 0.6 and 0.7, but sixaxis 0.8 works fine with my box. here you can find the fix http://freaktab.com/forum/tv-player-...ntroller-error
