Voyo MIniPC W8.1 bluetooth drivers
    Hi!
    After a fresh Windows 8.1 install I've installed Wifi drivers but with bluetooth drivers I can't find them
    I've tried in this post
    http://freaktab.com/forum/advertiser...LLING-WINDOWS=
    But the drivers don't work
    Anyone knows where I cand find them?
    Thanks in advance.
    Check here
    Drivers are the same...
      Originally posted by dp001 View Post
      Thank you, but if they are the same drivers i'll have the same problem, isn't it?
      I tried first the Lenovo's setup. No bluetooth chipset detected and then the update, without success too.
      Anyone has tried them with success?
        Nobody has done a clean installation of W.8.1?
          After update to W10 bluetooth driver was installed but it was a problem with the wifi driver. I reinstalled lenovo's driver and finally all works well.
          So, the install of W8.1 from USB is posible. After all I recommend do it.
          BTW, the over temperatura problem persists as in W8.1
