VIA VAB-600
VAB-600 Specifications
Model Name VAB-600
Processor 800MHz VIA Cortex-A9 SoC
System Memory 1GB DDR3 SDRAM onboard
Storage 4GB eMMC Flash memory
Bootloader 512KB SPI Flash ROM
Graphics Mali-400 SP GPU
2 integrated, independent 3D/2D graphics processing units
Graphics engine supporting OpenGL® ES 2.0 hardware acceleration
Supports MPEG-2, VC-1and H.264 video decoding up to 1080p
LAN VIA VT6113 10/100 base-TX PHY chip
Audio VIA VT1603A I2S Audio Codec
HDMI Integrated HDMI 1.4 transmitter
Expansion I/O 1 miniPCIe slot (supports USB 2.0 connectivity for optional 3G module)
Onboard I/O 1 USB 2.0 connector
1 DVO connector for TTL or LVDS display (corresponding daughter card required)
2 COM port connectors (TX/RX)
1 Miscellaneous pin header for 1 I2C pair and 1 DIO (4 GPI + 4 GPO)
1 SIM card slot (supports 3G module without built-in SIM card slot)
1 RTC battery pin header
1 Keypad connector
1 CIR connector
1 SPI Flash pin header
1 Front panel pin header for system power-on, reset and power LED
1 4-wire resistive touch screen FPC connector (through VT1603A)
1 Front audio pin header for Line-in, Line-out, Mic-in
1 DC-in connector
1 Battery charger connector with smart battery function (manufacturing option)
Back Panel I/O 2 Mini USB 2.0 ports
1 Mini HDMI port
1 10/100Mbps Ethernet port
1 Micro SD card slot
1 DC-in jack
Operating System Android 4.0, Linux kernel 3.0.8
Power Supply 12~24V DC-in
Operating Temperature 0°C ~ 60°C
Operating Humidity 0% ~ 95% (non-condensing)
Form Factor Pico-ITX (10cm x 7.2cm, 3.9" x 2.8")Data
There are currently 2158 users online. 0 members and 2158 guests.
