GTQ Android 5.1 TV BOX , Aluminium Metallicum , 1000M LAN , Support 4K/H.268/1080P
GTQ SMART ANDROID TV BOX-COLOR SILVER
Design patent certification
CPU: Amlogic S812 Quad Core up to 2.0GHz (Cortex-A9)
GPU:Octa core ARM Mali-450 GPU up to 600MHz
Bluetooth:BT 4.0
RAM:DDR3 2GB
ROM:eMMC 8GB
WIFI:IEEE 802.11a/b/g/n ,2.4G/5.8G
Ethernet:1000M LAN
UHD 4K*2K:Yes Support
Full HD 1080P:Yes Support
HEVC H.265/H.264 :Yes Support
GTQ SMART ANDROID TV BOX-COLOR SILVER Design patent certification CPU: Amlogic S812 Quad Core up to 2.0GHz (Cortex-A9) GPU:Octa core ARM Mali-450 GPU up to 6...
GTQ SMART ANDROID TV BOX- BLACK / SILVER Design patent certification CPU: Amlogic S812 Quad Core up to 2.0GHz (Cortex-A9) GPU:Octa core ARM Mali-450 GPU up t...
