Bob Video stutter take a look!!
    Bob,
    I do a lot of video coding and I was giving a thought to the stutter problem every ones having and noticed the same issue on another video streaming program besides netflix.
    The issue arised whe trying to play a PAL format video and right away noticed the stuttering that I see in net flix.
    I chose a different source the second time being that of a NTSC format video and the stutter was gone.
    Maybe it was the other way around??
    I am now thinking that there is some kind of error in the coding or codecs forcing video to be played in the PAL 25fps format on a NTSC 29fps GUI or vice versa.
    Thus causing the frame drop and giving a stutter image in video.
    The firmware should be edited and the value's changed to force NTSC 29.97 fps not PAL 25fps.
    Hmmmm..... good idea! I am working on a ROM for the 4.2.2 MK808 and I know where the codec binaries are.
    I will have a look see.
    Again good idea! Lets see if those codecs from 3066 will work on 3188.
