Problems installing a custom build
Hi, I have downloaded the Beast custom build into Kodi 15.1 (Link below) on an android MX3 box, the download too a while but unzipped ok then when I got to the Force Quit Kodi message I clicked it & an error message came up in the bottom right hand corner. Kodi didn't quit so I quitted it from my Android menu. When I re-opened Kodi it seems thet the Add ons all installed fine but there was no Skin, just the standard Kodi One. Can't seem to get it to work. Any help?Tags: None
I was having a similar problem on an MXQ box and couldn't work it out. It has since occured to me that if you come out of Kodi , enter settings on the box itself , then apps and then Kodi you will see the option to force restart. Hopefully that should work. I can't try it myself yet as I am at work tonight ; but I will be trying it out tomorrow.
There are currently 2746 users online. 1 members and 2745 guests.
