I ONE i68: Android 5.1: RK3368: Octa Core: 2G / 8G
    Beelink i68 TV Box 4K 1000M Ethernet
    HDMI 2.0 Android 5.1 RK3368 H.265
    Decoding XBMC KDDI Octa Core 2.4G 5.8G WiFi Bluetooth 4.0
    Another 3368 to feast your eyes upon..
    Thanks Gearbest and DHL prompt delivery
    Beelink
    Model: I ONE i68, Android 5.1, RK3368, Octa Core, 2G/8G Extended Capacity: 64G
    Media Supported Decoder Format: H.264, H.265
    Video Format: MKV, MPEG, MOV, 1080P, RM, ISO, 4K x 2K, MP4, AVI, DAT, WMV, MPG
    Audio Format: AAC, OGG, FLAC, RM, MP3, WMA
    Photo Format: BMP, GIF, PNG, JPEG
    Support XBMC: Yes
    WiFi: IEEE 802.11 b/g/n, Bluetooth: Bluetooth4.0 (AP6330)
    Power Supply: Charge Adapter
    Interface: SPDIF, Micro SD Card Slot, USB2.0, HDMI, RJ45, Micro USB
    Certificate: CCC, CE, FCC
    Product Size (L x W x H): 12.0 x 12.0 x 2.4 cm / 4.72 x 4.72 x 0.94 inches
    Package Contents: Beelink i68 TV Box UHD 4K HDMI 2.0 Mini PC, Power Adapter,
    HDMI Cable, Remote Controller, USB Cable, English Manual
    So whats in the Box all in order
    Look inside all the bells and whistles.
    Bit closer at all the Goodies.
    Not much underneath, Samsung ram
    And a Heat Sink underneath to get the cool.
    Well placed Holes in heat sink to take the Plastic Lug pertruding from top heat sink.
    WiFi AP6330
    Ports on Back, pending on how you look at it.
    The Internal Wifi Antenna
    The WI-FI module in this unit as seen is the AP6330
    Module that is used in the Tronsmart R68 is AP6335
    Just to keep it a little bit different.
    More to come
    Cheers
    trebor So is this the updated i68 with 1Gbit Lan?
      All indications it is 1 GB Lan by my Router
      Cheers
        Beelinks name brand means less and less as they license it out to whomever pays the most. Sad to see things go this way as I was initially excited about this box.
          I will bet it still has the 2gig storage limit and I also bet that Kodi will not passthru Dolby via HDMI.
            Perhaps, with their recent production problems Beelink have had to farm out production to other manufacturers, with the deal that they can use the Beelink name.
              Hi, I got this one. From Gearbest: http://www.gearbest.com/tv-box-mini-pc/pp_211700.html.
              It's OK but Netflix does NOT work on it. Also Kodi is unable to change refresh rate. Else it looks OK. The remote has short range and is terrible and I am unable to find an alternative remote software for this. Does anyone have a clue?
                I will test when I can get to the Amp in the other room.
                Not tested one of these devices on the amp can never get control it.
                Chance to test
                Plug in to Hdm AMPi
                Enable pass thru in Kodi
                Enable DTS...working
                Enable AC3....horrid noise
                Setting in android are Default, Spdf pass thru and HDMI Bitstream.
                Any further area of adjustment I should check or enable.
                Cheers
                Installed with KODI 15.2 and lots off addons .
