Firmware EM10 - OTT M10 S812 Amlogic
    Hi all,
    I am novice in the android tv box world, i just receveid a Android EM10 - OTT M10 with AMLOGIC S812 chipset but i have few problem... (impossible to turn off box, screen does not display information...) i think its a firmware problem...
    My product : http://www.aliexpress.com/item/Origi...433144539.html
    Anybody have firmware for this box or a new firmware ?
    I view lolippop is avaible for S812 sock but just for M8S , it's not possible to make lollipop for EM10 ?
    Thank you.
    WARNING I THINK IS A BAD PRODUCT (in this seller....)
    I have find this firmware : http://chinagadgetsreviews.blogspot....-stock_29.html
    but impossible to install because actualy rom is : kot49h.20150723 test-keys
      I have the same issue with you. But i also have the other that some app on google play store warning "Your device isn't compatible with this version", such as Facebook, Chrome, QuickPic .... So I notice If i search with key "youtube", the youtube for tv version is appeared, and youtube version for all of device not show. The M8S not have problem like that. I think the device type is difference with almost android box i've met. But i don't know which the file define that. Have you?
        hi, for my part my mx10 have... burn ! i think it was a counterfeit product (in kodi just see 2 core, box lag and freez ! and after it burnt !!!!) so I was refunded by aliexpress and I have ordered a MX3-G with lollipop. I really do not recommend the mxq M10 ! is not good !
