NEW SUPER ROM for Allwinner A80 from Sunchip (20150902) Android 4.4.2
    Do DTS and Dolby Digital play smoothly on KODI with this new rom? has anyone checked it out yet.
    also can someone help me out οn what is going on with the 3d movies on KODI? every time I watch a movie in 3d the movie keeps on shrinking and then expanding on its sides making you dizzy to watch. any solutions on that please?
      anyway, I decided to load the new rom.
      pros: it is faster than all the previous ones official or not
      kodi 14.2 has everything preinstalled
      also loads quite fast from power off (all other versions had to plug and unplug once or twice to get started)
      remote works perfectly
      cons: kodi's passthrough with DTS and DD still stutters.
      youtube won't load
      3d movies keep on shrinking sideways and expanding every now and then making the viewing impossible (but that was a problem since day one with tronsmart drako aw80)
        Originally posted by kacim View Post
        when I try to flash with PhoenixSuit.exe, here is the error message that appears..
        [ATTACH=CONFIG]n524121[/ATTACH]
        Just rename the file, omitting the chinese characters! it worked just fine with me with Phoenix Suit.
          Thanks druido.. I did it..
            This ROM is the best i tested to date..
              don't you have a problem with loading videos in youtube and dts & dd in passthrough in kodi???
