OTG USB A Male to USB A Male?
I'm trying to update my SunChip CX-R8 firmware but I'm having trouble connecting it to my computer. The OTG port is a standard USB A Female instead of a Micro USB. I have tried to use a Male to Male usb cable but my computer wouldn't recognize it. Anyone familiar with this that could help?Tags: None
I'm afraid that you can't use a Male A to Male A cable via the supplied OTG cable or using any other USB ports.
You will need a standard micro usb to USB Male a to connect directly to the OTG port.
Luckily they are dirt cheap these days.
Originally posted by bluesmanuk View PostI'm afraid that you can't use a Male A to Male A cable via the supplied OTG cable or using any other USB ports.
I have tried the english tool from http://www.android-warehouse.com/en/...ware-software/
and replaced the drivers with the ones from the link they gave http://blog.geekbuying.com/index.php...190455-150819/
No luck, still not detected. Tried all usb ports with a male to male otg cable on windows 7.
I flash it today and it was crazy, there is no exact tutorial. So i do my way, just steal from tronsmart.
1. Download http://www.mediafire.com/download/7j...hing_Tools.zip
2. Download flash image http://www.mediafire.com/download/ga...455_150819.zip
3. Extract and use manual Orion R68 updating instructions.pdf
4. USB port for update is that in the middle, on the side with two usb ports
I use standard USB 2.0 AA - Male/Male cable
Thats all.
But there is nothing important in update R8 Rockchip RK3368 2G 8G TV BOX 190455 150819 maybe next will be better.
SPIDF passthrougt still buzzing
Netflix not working
There are currently 2283 users online. 1 members and 2282 guests.
