Any way of merge partitions and root on the i68 (AP6330 - ethernet 100mbs)?
    I'm pretty happy with the device but I would prefer to have these two features.
    In the Wasser's rom the Wifi is not compatible because the i68 has the AP6330 and the R68 has the AP6335.
    Nobody need them?
    Hi you should be able to root it using iroot http://www.mgyun.com/m/en
      Thank you. I'll try it.
      And for merge the two partitions?
        Iroot should work it worded for me on my R68 same device different box.
        & for merge the two partitions Its not possible as far as I no you would need a custom rom with this already done.
        I no a freaktab member has been trying to make the 2gb partition bigger but has not yet had any luck with it
          Originally posted by Txemoto View Post
          two features...
          Give me the link to the firmware you are interested in. I will merge partitions.
          Root is in the cap of thread http://4pda.ru/forum/index.php?showt...#entry42533181
            Diman, I see that you are using the Tronsmart R68, do you have a rom that has the partitions merged? Did you solve the problem of box getting a different MAC address on every reboot? Also, how about DD and DTS passthru from Kodi via HDMI,
            thanks
              Yes +1
              It would be great to have the R68 rom with the partitions merged
                Yes +1
                Is your box grabbing a different MAC address every reboot?? That causes it to aquire a different IP address on your network, which is not good.
                  No, I do not have a R68. My device is Artway X6 on the chip rk3368.
                  Random MAC on LAN or WiFi? It can be corrected by script in init.d.
                  Wasser's firmware with the partitions merged.
                    Sorry the delay to respond.
                    This release, as I know, is the last oficial firmware update for the Beelink i68
                    Thank you in advance
                      Is this apk virus free? I have read that iroot comes with adware and for this tool Google advise me to avoid it
                        https://yadi.sk/d/C-8ACOdvjuUjz - repack firmware with new partitions
                        Flash by this tool in that order. Click image for larger version
                          https://goo.gl/ZCznn6 - repack firmware with new partitions
                          Flash by this tool in that order. [ATTACH=CONFIG]n523593[/ATTACH]
                          Has anyone tried this firmware is it ok?
                            Hi
                            i have Bricked BeelinK I68... when I try to flash the error READ IDB FAIL....
                            any solution? you can jumper the NAND memory?
                            Regards
