U65GT MIUI v6 for TWRP
    hello
    this is my mod of miui v6
    based on china miui port
    I delete all of chenese app and add polish language
    this port work on twrp lepi recover!
    sim not work! -maybe someone fix it.
    language, english, polish, chinese
    this is test build - if you find bug pleas raport.
    if you wont add your language use application jBART-master (work on linux and windows)
    link for rom https://drive.google.com/file/d/0B_8...ew?usp=sharing
    instruction of installation:
    -first backup your imei and your old system
    -wipe data ….cache….dalvik
    -Install rom.zip and rebot phone
    first start may take a long time
    Hi, I have tried your rom and one problem, I keep getting a 491 error with the play store and can't download any apps
    Cache wipes and reinstalling play store don't help. Any help would be great
    All fixed, Everything. Working fine.. Very nice
    Thanks. from mick
