Looking for Win10 drivers for Ainol Mini PC II Dual Boot Intel Z3735F Quad 1.8G 2G/32G 802.11 b/g/n LAN BT4.0
    Hi there, I have a rebadged one of these which i received with win8.1/Kitkat dual boot ... I am trying to remove android so that it is windows only
    Same box as this: http://freaktab.com/forum/tv-player-...-g-n-lan-bt4-0
    I have clean installed Win10 and removed all other partitions and allowed the win10 install to create its own partitions
    However device manager is showing around 10 devices that now have no driver installed
    Anyone know where i can download the w10 drivers for this box?
    And if someone could also point me in the right direction for turning off the dual boot feature I would be very grateful ... could not see a setting in the bios so maybe this requires changing the BIOS
    Many thanks
    Hi, why don't you try driver for pipo x7 driver from this wedsise,it work for me on transmart IZ37 win 10 pro,good luck
      TubbyMcLard : Same situation with mine. I purchased Ainol Mini PC II and I had many problems with the manufacturer's Windows 8.1 preinstalled image (e.g. Windows Home Edition have no option for Remote Desktop, Teamviewer had issues and so on). At first, I tried to upgrade to Windows 10 from Windows 8.1. Upgrade was successful but the RDP/Teamviewer problems remained. So, I decided to erase the disk and install Windows 10 Pro from scratch. I removed all partitions, including the partition with manufacturer's images.
      Windows 10 Pro had no problems with RDP or Teamviewer but there were driver issues. Most of the drivers that you mention above can be found over the internet by searching with the device's hardware ID (can be found at device's properties). In addition, someone can use Driver Pack Solution (http://drp.su/) to install them.
      Unfortunately, I still have problems with the display and audio. I know that the display driver is "Intel HD Graphics" and audio driver is "Intel SST Audio WDM" but these drivers seem to be customized by Ainol and the original drivers for Windows 10 from Intel's site do not work. I tried some other manufacturers but in vain. Moreover, the Driver Pack Solution cannot locate these devices/adapters. The same applies to similar driver-detective programs.
      I tried to contact Ainol about this issue but they don't give their drivers to the public!!
      I would appreciate if someone would upload the drivers for Ainol MIini PC II for WIndows 10 or even Windows 8.1 (backup the drivers from an existing image please!).
      As far as concern the dual boot feature, I think that it's not possible to turn it off. I cannot find an option in the BIOS for this, me too. Pesonally, it does not bother me at all beacause since I removed Android there is only the Windows logo option in the loader and I only have to wait for 10 sec for Windows to boot if I don't press any key.
        hi ,
        I have the exact same problem , i upgrade my ainol to windows 10 using windows update , and it seems that all drivers are installed in the device manager, connecting it to a tv doesn't work get no signal .
        Did any one found a solution ( video card driver for windows 10)
          Mine mini pc has still the original windows 8 installed, did someone manage to install windows 10 with working drivers?
          dimmat I can send you the drivers in case you still need them.
            Hi, someone maybe got the drivers? I have the same problem.. just updated the drivers and the graphics and sound drivers stopped working.
            Many thanks!
              I can send you the drivers, just let me know the file names
                Can you please contact me via email so I can talk with you about it (it's not only one file or something)
                My email is xxxxxx@gmail.com
                Thank you alot!!
                Last edited by superceleron; 27 January 2016, 00:56. Reason: don't give your email in a public forum... use PM.
                  eyal20, do you still have the drivers or can point me in the direction of these drivers for the Ainol mini pc, i''m at wits end, I can't find any drivers that will work?
