Beelink R89 and LG55UC970V 4K with true 10Bit HDMI Port
    Hello everybody,
    This Forum is awesome and i want to thank you first for all help, Firmware and Support that i found here.
    I have an Beelink r89 with the most actual Wasser Firmware and Wasser-Kodi15.1 Version.
    Everything works perfect and smooth. (yes only sometimes with a Little stutter - but i am not that sensitive)
    I have a few questions were you can hopefully answer:
    * Is it possible to use the LG Magic Remote with the Beelink R89? That would be really cool.
    * When i connect the R89 with the TV on HDMI 3 (10bit) and i try to change the resolution in the Androidsetting to 4k@60hz my TV Switches to a fully gray Picture (which is definitely wrong)
    interestant is, that i am able to Switch the very first time in the LG Settings to use the "Deep Colour" which were never possible before with other devices.
    so it seems that from a TV side everything should be ok. Does anybody have similar Problems? i tried 2 different HDMI cables 3m long (is it really important that the cable Supports HDMI 2.0?)
    It would be very helpful if you can give some hints...
    regards Elmaestroo
    There is much controversy with RK3288 HDMI output capability. To this day I haven't seen any proof that this SoC can output with 10 bit Color Depth per channel (30 bit RGB or Yc).
    See my previous posts: http://freaktab.com/forum/tv-player-...267#post419267
    There is my tool to read RK3288 HDMI registers and now for sure what output configuration is currently used:
    To use it you must have root permission but you may don't want to run some unknown code with that privilages. Then dump HDMI regs to file and than "feed" them to that program instead.
    HDMI registers localization:
    Android KitKat (4.4): /sys/kernel/debug/rk3288-hdmi/hdmi
    Android Lollipop (5.1): /sys/kernel/debug/rockchip_hdmiv2/hdmi
    Dump one of these virtual files to storage with cat FILE_NAME > PATH_TO_OUTPUT_FILE_LOCATION/OUTPUT_FILE_NAME.txt instruction in shell (i.e. with Terminal Emulator app).
    RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
      Hi Elmaestroo,
      Latest Wasser 3.0.0 rc2 has 4k (uhd) output issues.
      Wasser 3.0.0 rc1 has working output for UHD but has usb web cam bug.
      I use Mele F10 Deluxe air mouse for the box and for controling the major tv functions.
