Compile Keyboard Layout.....I need your help.
    I want to start compiling a list of keyboard layout files that is cwm/twrp flashable and manual one. But I will need some help. These are the ones that I own. I have another keyboard on the way and should get it by the end of the week. HERE I hope it is good.
    Please help and maybe if we get a good list they can bake these right into the roms. A link to the layout and name is good enough. I can search for the picture.
    I have a feeling that on the ones that are the same but branded differently we can just change the vendor and product id and they will work.
    If you need help finding out vendor and product id try HERE.
    Code:
    [COLOR=#000000][FONT=Tahoma][I]cat /proc/bus/input/devices[/I][/FONT][/COLOR]
    is the command you put in the terminal window to find the info.
    All Help is appreciated.
    Download Flashable Method
    Download Manual Method
    Rock Candy PS3 Controller Vendor_0e6f Product_0128
    W-Shark 500AC Vendor_0128 Product_6901
    Logitech K400 Vendor_046d Product=c52b
    Great idea.
    Microsoft Wireless Optical Desktop 2.10
    Vendor =045e
    Product=009d
    Logitech Unifying Device
    Vendor =046d
    Product=c52b
      Great idea.
      Vendor =045e
      Product=009d
      Vendor =046d
      Product=c52b
      Yes you have the same K400 as i do. But i couldn't find the other one. Vendor=045e_Product=009d.kl
      If you have that one and it is not already in the rom you are using can you share the kl file.
        Yes the unifying receiver is great for use of multiple devices.
        I'll have a look for that KL file.
