M8s s812 kicks me off KODI
I just received my M8S from Gearbest. I removed the version of KODI that was on the box and replaced with 15.1,and loaded my addons through KODI backup and restore. Now everytime I go into KODI it crashes and sends me back to the home screen. How can I fix this? Thanks in advance for any help.Tags: None
what firmware do you have and does it happen with all repo's?Bugs are Sons of Glitches!
JustMe
turk can you provide a link to your firmware I will have quick look also I advice switch over to 15.2rc3 now or you can try http://freaktab.com/forum/tv-player-...015#post527760
n200 zip and see if it improves your issuesBugs are Sons of Glitches!
JustMe
The same here mate? I just uninstalled it reinstalled another 15.2 version and now i cannot reinstall it with 14.2 again so i am stuck.It now constantly argues insufficient space on mine and i cannot edit vold.fstab on my own.Originally posted by terribleturk View PostI just received my M8S from Gearbest. I removed the version of KODI that was on the box and replaced with 15.1,and loaded my addons through KODI backup and restore. Now everytime I go into KODI it crashes and sends me back to the home screen. How can I fix this? Thanks in advance for any help.What is the world if you don't explore?
Originally posted by JustMe View Postturk can you provide a link to your firmware I will have quick look also I advice switch over to 15.2rc3 now or you can try http://freaktab.com/forum/tv-player-...015#post527760
I shouldn't bother with M9 firmware like i am using now to type this,as this is the firmware all my issues are arising from i couldn't even reflash or update using zip after installing it so be carefull,i know i had another M8S box well a N200 that i took up to the M8S firmware and that could reflash via sd anything i wanted including the xtreamer wonder firmware which i wrote a guide to in a thread i did,but i wouldn't do that,saying that i was stuck with no wifi but ethernet was fine,i couldn't reflash it via sd or update obviously but i think it could be possible now using the usb burning tool or img writing tool for amlogic devices,but do not quote me it's a risk people will have to take them selves.I just want an img file preferably lollipop an aml_upgrade.img file to flash mine with the img writing tool as i cannot write firmware any other way thanks to this locked down by the look of it M9 firmware,it's either locked or sd is inoperable for flashing hence it won't run it,it sort of tries then on erase it just falls over to the original firmware and your back to square one rebuilding from scratch again it is royaly p"ssing me off now and i am not getting any support here,the worst part is i can get update.zip roms but i can't convert them into an img file otherwise i'd do the lot my self,and try other methods of cross flashing and report my findings with guiides on here.Any help with a img would be greatly appreciated as i can probably regain update from within the os via zip files at that point,but for now i am scr@wd.Originally posted by terribleturk View PostWhat is the world if you don't explore?
Originally posted by clayton319 View PostYou and try TVMC compiled apk from tv addons it seem to work for meWhat is the world if you don't explore?
There are currently 1531 users online. 1 members and 1530 guests.
