MXV with MK808B Plus Firmware?
Thank you for the replay but I want to "run" Openel from SD card without touching the box.
While you were wrinting I was adding this to my post:
.....Could you please help me? Thank you in advance for the reply.
Edit: 2015-01-05 :
Finally replacing the file recovery.img with another one (trwp) it started with openelec. I have to press the button below the case that act like the pin to push "somewhere" in these boxes.
But during several tries I crashed the box (I suppose the bootloader) I mean I've created a bootable SD card with the image of OpenELEC-Amlogic.MK808B.Plus.arm-5.95.5.2.img and it doesn't started (I knew that it wonìt started but I wanted to see the behaviour of the box). Now I need to take pressed the power button otherwise the box shutdown. Knowing that one time that it is started I can "power off" with the remote control that leave the box in a stand-by mode.
Have you a suggestion how to fix it without flashing a rom againg?
Thank you again.
Originally posted by cassioac View Post
Hi mwp1
How did you manage to install Openelec on MXV
Whenever I try to install it to NAND, I must keep pressing the power button the whole time while flashing (or it turns turn off as soon as I release the power button), also after it flashes successfully, power button must be kept pressed as well or it turns off briefly after I press it to turn the device on, doesn't matter if booting from NAND or SDCARD.
Did you run into this kind of trouble with your MXV?
Which steps did you take to make it work?
I had the same problem but this fixed it for me so might be worth a try...
Get a USB Male to Male and plug one end in port 1 USB and the other into port 4 USB, when I do that, the box stays on even if the power button isnt held down. As soon as i unplug one end of the USB, the box turns off. I have no idea why this works.
There are currently 1945 users online. 1 members and 1944 guests.
