Can't install language pack
    Hi everyone,
    I bought a second hand dual boot (Android / Windows 8.1) tablet today and decided to factory reset the android and windows side..
    The Android side went well.. I was able to change the Chinese language to English fine.. however, the Windows 8.1 side I can't change the language.
    In the options there's no option for downloading the language pack..
    I've tried adding a few different languages and although I get the option and seems like they're loaded, I don't have the option for downloading the language pack for them..
    It came to me in English, so I'm not sure what was done/took away with the factory reset...
    Any help greatly appreciated!!
    PS. the tablet is a Cube Iwork8 3G
    Success!
    The way I did it in the end was to do it via the control panel.. and use English (Irish)
    Doing it via the side panel / settings didn't work. Once I was in the control panel, all worked..
    It started doing the English (UK) ok but froze.. and when I tried again it no longer had the option to download the pack.. so I switched to English - Irish, and all is well again !
    Then to change the log in screen into English I followed the instructions at the end of this video
