Who makes this device?
I don't have any knowledge of this device, but many report heat issues with many RK3288 sticks. Look for support before you buy, otherwise you may be stuck with poor F/W. Please see my general buying guide here, the first four posts are relevant.Last edited by RISCy Dude; 26 September 2015, 19:43.
Originally posted by plasma View PostYes
What is the best CPU version today?
But you also have to look at brand name/manufacturer.
There are big differences.
Eg. Nagrace has very high quality boards with big heatsinks and more capasitors than other boards, also has faster memory and storage space than other manufacturers.
CPU is not the only thing you should look at.
Originally posted by neomode View PostGet yourself a CS008 RK3288 TV Stick.
Realy good Device and Stable.
Neomode
Good and stable are not a good definition to CS008. I have one (Realtek chip) and the firmware is very poor. Stick reboot when it connects to WiFi or when I install/open an app and the list is big. I'm trying to save this stick but new firmware to this device is near to impossible. No more anonymous brand.
Miguel
Originally posted by neomode View PostThis Device is good I share my Firmware I make for it. Then all is good.
Gesendet von meinem C6603 mit Tapatalk
Interesting, neomode. Two questions: 1. Your firmware support the new CS008 with Realtek chip? 2. If it is yes, where/how I get your firmware?
Thank you
Miguel
Hello Miguel,
First thing all RK3288 TV Sticks use the same PCB. Even if you use a RKM one or from ENY with different Name. Only difference is Wifi chip. I will Upload the Firmware I make for it later. And yes it is for that Wifi Chip and Works perfect.
Regards
Neomode
Hello, neomode I wrote to you a PM.
My CS008 constantly reboots... I'm not able to work with this device in any way
video: https://www.youtube.com/watch?v=RmY-...ature=youtu.be
Hello baklazanowy.
I had that problem for a long time; I was very frustrated with the CS008. I discovered the solution casually: the power adapter.
My CS008 came with a power adapter of 5v/2.0A and with it doesn't work good. Try it with a power adapter of 5v/2.5A; for me, that was the solution to the constant reboots.
Greetings.
Miguel
There are currently 3452 users online. 1 members and 3451 guests.
