can anyone here have the firmware or have the files to get the remote working with openelec .
Help with s805
Help with s805
I bought this android tv box with kodi fully loaded and I have a problem with almost all the videos addons they do not work just empty list or getting failed errors a tried both wifi and Ethernet I tried different firmware but all of them have the same problem or the kodi dose not lunch at all I have tried to search the Internet for the original firmware which came with the box but I can not find it the firmware no is kot49h.20150814 I also tried using openelec both on flash and on SD card the kodi works fine with Ethernet but with wifi I get the same errors like on android which means all the problems are related to a bad Internet connection or bad hardware the other problem with openelec is with the remote not working and its to complicated form my to get it working .
can anyone here have the firmware or have the files to get the remote working with openelec .You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
Originally posted by neomode View PostNo worry.
What Image you Flash M8 or T8?
You can unbrick your box with AML USB Burning Tool and an Probox2 Ex Firmware Image.
Also send me a Picture of your Box.
Neomode
I have tried the USB Burning Tool but the pc can not see the box .
here are all the picutres of the box I have http://www.aliexpress.com/item/MXQ-S...350039877.html
Originally posted by neomode View PostI send you a link for Firmware to reflash tomorrow.
Don't worry, am will be fine again.
Neomode
Thank you very much
There are currently 1965 users online. 2 members and 1963 guests.
