Bricked M8S+
Bricked M8S+
In another post I described a problem with Kodi shutting down and sending me back to the home page. I decided to load the new Lolipop 5.1.1 firmware to see if it would help. The upgrade started out well, but then terminated after erasing the previous firmware. Now the box turns on via toothpick method but only goes as far as the boot screen. I have tried loading numerous firmwares via SD card, bootcard maker and USB burning tool, all to no avail. Any help or suggestions would be greatly appreciated.
Tags: None
Success!! After almost a week of searching and reading all over the net, I found my solution on Stane's site. I made a bootable SD card with the USB burning tool image for the M8s+ , uboot bin and aml_sdc_burn.ini on it. Used the toothpick method and restored the unit. So far Kodi working very well. Many thanks to all those ,such as Stane who spend the time to research and make this info available.
Originally posted by m8splusUser View PostThat's great news.
Do you mind providing some more information:
1. Were you able to get Lollipop working or you had to revert back to Kit Kat image?
2. Which Kit Kat image did you end up using? Can you share the link or the source of the image..
Thanks in advance!!
There are currently 1963 users online. 0 members and 1963 guests.
