Help Compiling TVheadend on Arm Linux RK3288 and S805
    CC tvheadend
    /usr/bin/ld: /home/minipc/tvheadend/libav_static/build/ffmpeg/lib/libx264.a(opencl.o): undefined reference to symbol 'dlsym@@GLIBC_2.4'
    /usr/lib/arm-linux-gnueabihf/libdl.so: error adding symbols: DSO missing from command line
    collect2: error: ld returned 1 exit status
    Makefile:530: recipe for target '/home/minipc/tvheadend/build.linux/tvheadend' failed
    make: *** [/home/minipc/tvheadend/build.linux/tvheadend] Error 1
    I was hoping that someone might be able to help with this. Cant finish compiling on 2 different arm boxes and get exact same error. Been searching for hours to try to resolve.
    From Stackoverflow
    Code:
    In general, the man page for the symbol you can't find tells you what libraries you need to link in. In your case:
    http://linux.die.net/man/3/dlsym
    Note the line:
    [B]Link with -ldl[/B].
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
      I'm Linux noob can you elaborate. I did find that stack overflow. I just don't know know how to apply the response.
        It looks like an error on the Makefile. Can you upload it ?
          I believe this is it
          Tvheadend is the leading TV streaming server for Linux with ATSC, DVB-C/C2, DVB-S/S2, DVB-T/T2, IPTV, SAT>IP and unix pipe input sources - tvheadend/tvheadend
            BTW it compiles and works if I don't use ffmpeg static. Only errors when I use ffmpeg static
              Here are the steps i took and sources for information if someone else wants to take a stab. it builds fine with no static ffmpeg. Built on r89 with linuxium img very little testing with non transcoding version.
              Sources and info
              iconv, recode, internationalization, i18n, multilingualization, m17n, transliteration, Unicode, ISO-8859-1, ISO-8859-2, ISO-8859-3, ISO-8859-4, ISO-8859-5, ISO-8859-7, ISO-8859-9, ISO-8859-10, ISO-8859-13, ISO-8859-14, ISO-8859-15, ISO-8859-16, KOI8-R, KOI8-U, KOI8-RU, CP1250, CP1251, CP1252, CP1253, CP1254, CP1257, CP850, CP866, CP1131, MacRoman, MacCentralEurope, MacIceland, MacCroatian, MacRomania, MacCyrillic, MacUkraine, MacGreek, MacTurkish, Macintosh, ISO-8859-6, ISO-8859-8, CP1255, CP1256, CP862, MacHebrew, MacArabic, EUC-JP, SHIFT_JIS, SHIFT-JIS, CP932, ISO-2022-JP, ISO-2022-JP-2, ISO-2022-JP-1, ISO-2022-JP-MS, EUC-CN, HZ, GBK, CP936, GB18030, EUC-TW, BIG5, CP950, BIG5HKSCS, BIG5-HKSCS, ISO-2022-CN, ISO-2022-CN-EXT, EUC-KR, CP949, ISO-2022-KR, JOHAB, ARMSCII-8, Georgian-Academy, Georgian-PS, KOI8-T, PT154, RK1048, ISO-8859-11, TIS-620, CP874, MacThai, MuleLao-1, CP1133, VISCII, TCVN, CP1258, HP-ROMAN8, NEXTSTEP, UTF-8, UCS-2, UCS-2BE, UCS-2LE, UCS-4, UCS-4BE, UCS-4LE, UTF-16, UTF-16BE, UTF-16LE, UTF-7, C99, JAVA, wchar_t
              mkdir hd
              cd hd
              wget http://download.silicondust.com/hdho...n_20150826.tgz
              wget http://download.silicondust.com/hdho...i_20150826.tgz
              tar zxvf libhdhomerun_20150826.tgz
              tar zxvf hdhomerun_config_gui_20150826.tgz
              cd hdhomerun_config_gui/
              sudo apt-get install libgtk2.0-dev
              ./configure
              make
              sudo make install
              cd ..
              cd ..
              All packages
              sudo apt-get install build-essential git pkg-config libssl-dev bzip2 wget
              sudo apt-get install libavahi-client-dev zlib1g-dev libavcodec-dev libavutil-dev libavformat-dev libswscale-dev
              sudo apt-get -y --force-yes install autoconf automake build-essential libass-dev libfreetype6-dev \
              libsdl1.2-dev libtheora-dev libtool libva-dev libvdpau-dev libvorbis-dev libxcb1-dev libxcb-shm0-dev \
              libxcb-xfixes0-dev pkg-config texi2html zlib1g-dev dvb-apps liburiparser* libiconv-hook1 libiconv-hook-dev libicu-dev
              wget http://download.videolan.org/pub/vid...stable.tar.bz2
              bzip2 -dc x264-snapshot-20150908-2245-stable.tar.bz2 | tar xvf -
              cd x264-snapshot-20150908-2245-stable/
              ./configure
              make
              sudo make install
              cd ..
              wget http://ftp.gnu.org/pub/gnu/libiconv/...nv-1.14.tar.gz
              tar -zxvf libiconv-1.14.tar.gz
              cd libiconv-1.14/
              nano srclib/stdio.in.h
              search for "rare"
              change
              /* It is very rare that the developer ever has full control of stdin,
              so any use of gets warrants an unconditional warning. Assume it is
              always declared, since it is required by C89. */
              _GL_WARN_ON_USE (gets, "gets is a security hole - use fgets instead");
              #endif
              to
              /* holli to avoid make error
              #if defined(__GLIBC__) && !defined(__UCLIBC__) && !__GLIBC_PREREQ(2, 16)
              #endif
              #endif
              ./configure
              make
              sudo make install
              cd ..
              git clone https://github.com/tvheadend/tvheadend.git
              cd tvheadend
              ./configure --enable-hdhomerun_static --enable-hdhomerun_client --enable-libffmpeg_static
              make 11:20 start
              ./build.linux/tvheadend
              make install
              cd ..
              Build this if not static
              wget http://ffmpeg.org/releases/ffmpeg-2.8.tar.bz2
              bzip2 -dc ffmpeg-2.8.tar.bz2 | tar xvf -
              cd ffmpeg-2.8
              ./configure
              make
              sudo make install
              cd ..
              ERROR
              CC tvheadend
              minipc@localhost:~/tvheadend$ ./configure --help
                Build notes and steps
                mkdir hd
                cd hd
                ./configure
                make
                sudo make install
                cd ..
                cd ..
                All packages
                ./configure
                make
                sudo make install
                cd ..
                cd libiconv-1.14/
                search for "rare"
                change
                #endif
                to
                #endif
                #endif
                ./configure
                make
                sudo make install
                cd ..
                cd tvheadend
                make 11:20 start
                make install
                cd ..
                cd ffmpeg-2.8
                ./configure
                make
                sudo make install
                cd ..
                ERROR
                CC tvheadend
                  Are you trying cross compile for android? if yes,
                  The problem is in Makefile.ffmpeg.
                  It uses linux gcc instead the android NDK. I also tried with no success when enable libffmpeg_static.
                  Also you need to add many flags to each ./configure
                    No this is for Linux on my beelink r89. It might have enough power to transcoded to h.264
                      There is a switch in the make file for Android. Should I give it a try?
                        no the --enable-android is for cross compile.
                        with transcoding your cpu will be 100% because you need to encode and decode in the same time..
                          I found a post where someone is doing this on an odroid-c1 successfully. I hope someone can hash this out. I took good notes if someone with more knowledge can try.
                            got it working
                            LDFLAGS += ${LDFLAGS_FFDIR}/libx264.a
                            to
                            LDFLAGS += ${LDFLAGS_FFDIR}/libx264.a -ldl
                            and ran
                            ln -s /usr/local/lib/libiconv.so.2 /usr/lib/libiconv.so.2
                            Testing to see if the r89 can transcode
                            Will post slim down directions after i clean up
                              well i can get it to transcode on the rk3288 at low resolutions fluidly 1.5mbps skips occasionally. Next to try on MK808B plus and hope that the hardware acceleration kicks in.
