I have an environment where I need video output from both ports. The problem I am facing is that seems that just one may work at the same time. When the TV conected to the HDMI port gets up, automatically the one conected to the AV port switches off image. If I disconnect the HDMI cable, the AV port works back automatically. There is any workaround to have those devices sending signal to both AV & HDMI ports?
Thanks!
