Power Issues with M8 (Square Box)
Hi All .. I'm hoping one you you experts will be able to help me out .. When I plug in the power adapter for my M8 the light goes blue and loads up to the Quad core Processor screen for about 10 seconds then the blue light goes out and the screen goes blank .. It was working fine the other day .. Thanks!Tags: None
change power supply if you have one on hand or reflash box with oem fimware again diagnosing issues like this is virtually imposible without eliminating things
also try another tv before reflashing and buying new psu certain tvs have issues
try those and report backBugs are Sons of Glitches!
JustMe
Hi JustMe .. Thank you for your reply .. I have tried 2 other power supplies with no luck .. I tried reflashing with your firmware and finless firmware but box doesn't stay on long enough to flash .. I'm still trying to find the original firmware .. I have tried on 2 Tvs didn't work.. I have also seen something about shorting out the pins .. should I try that and can you point me in the right direction for a guide to do it .. Thanks again!
There are currently 3012 users online. 2 members and 3010 guests.
