Help finding firmware for Amlogic S812 - Ott TV Box - Square - 8 gb Rom 2 gb Ram - 6330 AP
Originally posted by Santos954 View Post
Can I ask you where you got that 5.95.3 zip please? one of the cores is at 100% with nothing playing or anything, the box is pretty warm as well. Is that normal?
OpenElec Amlogic
Sent from my D6603 using Tapatalk
Originally posted by RoyLee View Posthello folk unfortunately you got a clone one. there is a easy to tell original or clone box. just look at the heat sink. original's always bigger, and you can take off original's heat sink easily. not for clones, cos they use something almost like glue to stick it on. check my picture. you really need to try many firmwares for clones to get a suitable one.
Hi, everybody and happy New Yaer!!! I have OTT M8S+ S812 with Android 5.1 but I want to know if I can upgrade to Android 6 or Android 7, and if I can... can you helpme please why I can do this upgrade? Thanksand I have installed the last firmware on decembre 2016..
hey folks, i have an M8S which has M9&M8_8bit_V1.1 written on the PBC. i tried to upgrade the firmware and it got bricked. i have tried all recovery firmware i could get here but non seems working. i was almost lucky with the USB burning tool but always got stuck at 96%.
i need to get this box running again. pls help
There are currently 4157 users online. 1 members and 4156 guests.
